A/C disconnect clearance?
Pattycakes
Can my mini split disconnect go right underneath this service receptacle? Condenser will be to the left… this is obviously accessible but I’m unfamiliar with and wondering about vertical clearance. Condenser will be under the window. Thx 1341C62A-8863-42C1-8839-0B5BD40FCEAE.jpeg
P
Pattycakes
Thanks both!. @nadogail , what I am confused about is whether or not the receptacle located directly above the disco would infringe on the vertical clearance requirement. It sounds like as long as the cover can be opened fully as designed then I am good to go. Fair? Thanks again
nadogail
Coronado, CA
Any Technical Information you take from me is Guaranteed to be worth exactly what you have paid me for it.
sparky 1971
Central Iowa
No, because it is not infringing on the working space. If it stuck out far enough that you couldn't be in front of the diso without banging your head it would be a different story.
