Just finished my shop and its on the bigger side (30'x50'x14') I live in the middle of the desert ( inland empire of so cal) The last few weeks have been warmer than average . high 90s low 100's and first day of summer was 113 here. I havent been able to work in shop much because of it being so hot . Looking into an a/c for it . It is insulated and i do have 3x 60" ceiling fans im installing in the next week along with a hundred other projects im trying to finish. The first is a/c or something to cool it a bit more tolerable to be productive. I know for that size i need a real system. not a mini split but an actual 5 ton split system . I have plenty of power and even gas though i dont plan to run heat but if im going to install a system my as well since everything is there. I am confident i can install it myself and wire/charge and run all lines without issue. Just trying to debate what to go with , an older used r22 setup i can get for cheap , rehabilitate and only use when needed with a wifi thermostat. Or spend a bit more , possibly find a newer used 410 unit with a more efficient compressor . The indoor unit will go on a mezzanine i have in the shop in the upper corner with one large 20" duct running accross the 50' side with reduction couplers and vents every 8-10 feet. Not looking for a swamp cooler or anything that introduces humidity.
Just looking for opinions on what route to go , any others in a similar situation.
