A/C overflow shut off required by code?
hal1
Phoenix
I'm guessing each state is different, I live in Arizona. But, does anyone know if there is a code requirement that an A/C unit have a secondary drain pan shut off switch?
larry4406
Northern Virginia
I thought it was an either or scenario - pan overflow drain or a switch.
I prefer the switch as it stops the unit alerting you to a problem.
If the drain handled the issue, it will keep draining as the unit remains functioning and the user is none the wiser.
Our new homes come with a pan and float shut off switch.
gtae07
Fayetteville, GA
We have both. The overflow drain exits at a different and much more noticable place so it should tell you there's a problem (assuming you know/remember what it means). If it's blocked (and it was, once) the switch cuts things off.
Git
S Cal
In my house, the original 20 year old AC in the attic has a drain pan only. In a completely new system that was installed in 2020 (we have 2 separate systems, one for 1st floor and the other for 2nd floor) they installed a float switch in the drain pan.
With that being said, I do not know that our code here requires it, but for $12 it could save a lot of grief down the road if the drain pan were to overflow. It's wired to kill the power to the thermostat which will shut the whole system down but I understand in areas that can really cold, it would be wired to kill the power to the outside condensor so the homeowner could still run the furnace and not freeze to death in the winter
mike93lx
Richmond, VA
Mine are pan and float shutoff for the two above finished space and just a float shutoff for the one in the garage
The garage and one unit over living space are recent installs, but I don't know if it's a code requirement or best practice
H
hal1
Phoenix
Yes, easy enough, I just have to find where plug/wire it in on my unit. But I'm also thinking one of those water sensors might give me even earlier warning
jacob_coulter
I'm pretty sure it's not "code" but some insurance companies mandate it. Mine did, first summer the thing gave a wrong reading and shut my unit down. I unplugged it and didnt have a problem since.
A different unit had them and it never gave me any trouble.
Git
S Cal
Usually the Red wire to your thermostat is power. Float switches are 'normally closed' so if the switch trips, it kills the power to the thermostat.
