So I bought a brand new leftover from last year 28,000 btu Frigidaire for my well insulated garage. It cools it down awesome!! I've only ran it about 7 days (not continuous) It worked GREAT until today. When working like it should, you turned it on and could hear compressor kick on and "load" down and would blow ice cold air. So today I turned it on, I could just barley hear the compressor kick on, there was no "load" sound to it, and its not blowing cold air.. Tried few things off/on and nothing. Called Frigidaire cause there is suppose to be a warranty, said they are going to send someone out once they fine someone in my area. Sounds like load of ****, but I will call back in a day or two see if they still are.
So you a/c guys, is there any simple things I could check on a 7 day old a/c unit that just stopped blowing cold? If it had a leak and was low, the compressor wouldn't even try to kick on would it? Or if it is low would it still kick on but you wouldn't hear the "load" sound?? just thought i'd check with you guys before they send some guy out that wants to do nothing but not help me. its like a $900 a/c unit so I sure hope the make it right, but I have feeling i'll get short end of stick
) cost cut !
Actually, I've never seen a window unit (or any residential appliance) with OEM service ports. To me, to find service ports on that type of equipment is a sure sign it has been messed with. It's an absolute if it has piercing type ports.
