I am installing a set of case covers on my motorcycle. The bolts that came with the covers are stainless steel. Since these will be going into an aluminum engine block, I know I need to apply some anti seize prior to installation. My question is which type should I use? I already have some regular Permatex aluminum anti seize, but I also know they make a copper and nickel based anti seize as well. Is it ok to use the aluminum Permatex that I have, or should I buy one of the others types? Also, how much do I use? Be generous with it, or does a little go a long way? Do I apply it to the whole bolt thread, or just to the end of the bolt? I appreciate any advice you can give me. Thank you
