I'm wiring garage lights, 40X44 detached structure in it's own little world away from the house.
I have some 14 gauge wire I was planning to use for lighting circuits. From the panel it will go to a switch then to a row of ceiling light fixtures. From that row, I'd like to continue on to the other side of the garage to power some exterior lights. Is it permissible to run 14-3 out of the switch box to a ceiling box with the one switched wire for the lights (lets say red) and an always hot (black) wire to go on across the garage. At the ceiling box, the red and white go to the switched fixture and the black (and white) would connect to 14-2 the rest of the way across. Tie all the whites together of course.
Second dumb question. There will be 4 rows of lights and each row will need to be on it's own breaker. I'm assuming it's no issue to have 4 separate feeds going into one 4 position gang box with the 4 switches?
