A deal to share! Blockheads look here!
mrpizza
IL
So today for my 1000th post, I decided to share a deal I got the other day. It's a craftsman 1/2 HP block grinder in good shape. It has both shields, all covers, and the little basin for water that sits in the front. I want to fix this thing up and make it look awesome. Any advice? It does vibrate like a mofo but I think the wheel is not balanced on it.
Oh yeah, it's a deal because it was FREE!!!
Itinerant
Behind the Zion Curtain
Nice Miles, love those block grinders. :beer:
Apologies for all the questions, but can you make out the model number? Do you know if the eye shields are home fabbed or adapted from another machine? I've never seen anything like them on a block before, are they mounted on some sort of swinging arm?
Enjoy.
zkling
Wow congrats. As for the vibration issue I'd be willing to bet it is with the wire wheel. Start by taking that off and see if it still vibrates. Is so, then remove grinding wheel and test again. Process of elimination. The last wire wheel I used had horrible vibration issues. Sectional density problems. And yes it was a good quality USA made wheel :dunno:
BreeStephany
Oregon
Is the label a sticker or a plate? If it were mine, I would strip it down, powder coat, replace the bearings (if you can find parts) and hardware (screws, bolts, etc.) with stainless hardware as well as rewire it and replace the switch if necessary.
I'm kind of a sucker for powder coating for 3 reasons, it looks great, its durable, but most importantly, most powder coaters use a good chemical bath to strip off every ounce of paint, dirt, oil and whatever else has made its way on the metal over the years, leaving the original surfaces to work with, which in turn means less cleaning for me.
The label looks like a sticker and is likely too far gone for it to be salvageable. If you want to get it back to original, I would see if someone has one with a label that you could duplicate from, have them take a picture and then have someone with a little photoshop experience clean it up, make it into a label and then print it on vinyl or a similar material.
If you really wanted to get fancy, you could make a tin label for it. Its a bit of a pain and is a multi step process, but it definitely looks great and 'factory quality' when your done. I had a friend make me vinyl templates with their cricut (computer controlled matte cutter) and then airbrush on your layers over the templates.
mrpizza
IL
I'll pull the wheels tonight. The label is absolutely gone but I'll check for the model number when I get home. My father in law gave it to me, so I gave him a grandchild! I'm not sure about the shields, they look factory and are adjustable up down, swing to the side and tilt fore and aft. Switch works great as does the light. Hopefully this weekend I can tear it apart and check out the bearings and all.
jakemac
New England
To find the model # you may need to use a flashlite and magnifying glass. Shine the light on the label plate at several odd angles, you may be able to pick up the marks from the imprint even if the ink is gone.
mrpizza
IL
Looking at my picture I can see that the red writing is still there for the model number. I do have a magnifying glass so I'll check it out when I get home. Where is the best place to get bearings for it? It spins smooth but I'm not sure if there is any lateral play in the bearings.
zkling
For water to dip the piece you are grinding in to cool it. When sharpening cutting tools you don't want to over heat the edge as you will ruin the heat treatment. Keeping it cool prevents that. Grind, dip, grind, dip. Grinding is a friction process, friction creates heat, heat builds up on thin edges very fast. If it changes color to say a straw, blue or even glowing red you are already too far gone.
drivesitfar
Miles,
i thought somebody would have mentioned this already so i will. there is a thread ongoing with a ton of information on Craftsman "block" grinders. here is where pretty much any answer lies to all your questions and the best place to post any after you have read the thread and still have some.
there are plenty of links to the threads on total restores to places to buy the rubber gromments for your block to rest on.
good luck and after reading the block thread i bought a couple blocks and am thinking of selling some of my expensive "old school" ones that might be better quality because there is so much help on Garage Journal and that thread if i ever have an issue.
