andyvh1959
Around my house, not the garage. My house was built in 73, on very sandy heavily wooded west side of Green Bay. Its a tri-level, so there is a ground/slab level, and two other levels above. The basement is small, only under the center of the house. There is a sump in the basement with a sump pump. Even this time of year there is some water draining into the sump pit.
But I'm sure the drain tile is full of tree roots, especially after 45+ years. Though I wonder what was used for drain tile back in 73, maybe plastic, likely clay tile. I am really tempted to dig down outside a corner of the foundation to get down to the drain tile and find out. If I do that, I may install a large tee system, onto which I'd add a riser section to end above the lawn/grade level, with a service cap. At least then I could yearly apply chemicals into the drain tile to kill/clean out the tree roots.
Anyone else have direct experience with this. Or is it a level of work that once I am into it, to only do it right/completely is to dig all around the house to replace all the drain tile? At really heavy rains I do get some moisture in the basement. I've already done all the gutters and downspouts to drain well away from the house.
Another alternative: during the dryer summer months, install a riser pipe into the drain tile in the sump pit. Then fill the drain tile with the tree root killer/cleaner chemical. Once it has filled the drain tile and set for a week, take the riser out and hopefully I'll have cleaner drain tile. I've been in the house since 2002 and for many years I never had any water/moisture in the basement.
