Hi all-
My electrician buddy who's helping/advising on the side is hard to get ahold of, hope someone here can answer a few questions before I do anything else lame.
Lame? Why yes, I made about 15 very nice jumpers for grounds in my quad boxes before finding out I can only put one wire on a screw.
Here's what I've got:
15 2x4' T8s on four circuits.
That works out to less than 15A, so I can run one 15A circuit on 14/2 to the box, right?
Do I need a GFCI?
6 quads for the workbench, with a GFCI first in line on 12/2. 20A breaker, 15A outlets.
Do I need a 20A GFCI? Are 11 duplex receptacles in a row okay?
Second circuit is working out to about 4 duplex and 9 quads. Same drill, 20A breaker, 15A circuits.
Can I run that many outlets (22!) on one circuit off one GFCI? Most of these outlets will probably never get used, not that it matters...
One of these is for the garage door opener, should that be pre- or post- GFCI?
I'm in California, and didn't see any mentions of this stuff in the local code. NEC is a little overwhelming for a layman.
I have yet to run the feeds from the box, so now's the time to plan the layout. Lots of room in the panel, lots of open breakers.
Do I need a GFCI?
