A hack to short Morse taper for lathe
wxm
I have this no name (imported?) chuck for a while. I came with the lathe, but it was painful to use it as the taper end was cut short by the previous owner and I would not eject when tailstock was fully retracted.
One way to address the issue is obviously replace the MT2 taper, but I don’t have the wedges to loosen the Jacob taper on the chuck end. Plus, I owner a good 1/2” Jacob chuck, don’t feel like spend too much on a Jacob taper for this import chuck.
So here is my hack to get the ejection to work. The idea, might have from one of the post here, is to add a short round stock which extended the taper long enough so it will catch the center pin and push itself out. But I don’t really want to deal with “fishing” the round stock with magnet when switching to other inserts. So I decide to drill and tap a 1/4-20 hole and I then screw in a 3/4 length bolt...
Here a few pictures of the process, and the final “product”. The bolt is put on with lock-tite, in case I need a shorter taper for whatever reason. I can just remove the bolt.
Didn't really have a good way to clamp down the the taper with chuck on it. So I locked the chuck on a 3/8 mandrel, and then clamped the mandrill in a collet chuck.
Started drilling with the center drill.
After a few iteration of the drill bits, finally ended a 7/32" hole.
Tap into 1/4-20 thread, first with a starter tap in the tail stock
Completed the threading with the tap wrench.
why worry
Nice job where there's a will there's a way as my Grandfather used to say....
Dave
larry_g
oregon
I have a few of those that have come my way. The screw makes it easier to adjust for the different spindles. Good Job.
lg
no neat sig line
matt_i
Good stuff, I am curious about the 7/32" pilot diameter for a 1/4-20. I've tapped a few (thousand!) of those and used #7 always...or a 13/64" is a good "hack" since its only off by .002". Was the material hard and needed the thread contact reduced?
W
wxm
I suppose the 13/64 might be better. It felt too “easy” when I was tapping it. But my drill chart says 7/32 and I don’t have 13/64 anyway. Guess it is ok for this applixcation as it doesn’t take too much stress.
eicke
Just did this but used a real short 5/16" socket head capscrew. Looks more like a tanged arbor.
Millwrong
Canada
Nice work! MT2-JT Shanks are like $5-$10 on ebay for next time though...;) Is there no tang slot on your tailstock quill?
W
wxm
My atlas craftsman lathe has no tang slot. There is a center pin which serves as a ejecting mechanism.
