A Large Work Bench w/o Breaking The Bank
Skin
Boston
So I've wanted a new LARGE (8-10ft) work bench for awhile and was pretty set on getting one through Zoro with a Butcher Block top. Problem is I could never wrap my head around the price, even post sale i'd be looking at over $500 for some stamped steel legs and the single work surface. I don't mind spending for quality but it irks me to spend so much for so little.
Anyway I stumbled across a company called 2x4 Basics that sells kits. Pretty simple, they give you the legs/shelving guides, screws, and instructions, you supply the wood. They advertise no fancy cutting required, just a circular saw. I checked out the reviews on Amazon which were good and I liked what i saw in the review photos which started the hamster wheel in my head rolling. I purchased through Amazon and got the full kit for about $65. I made a couple trips to the big box store for some wood and all told I think that bill ran about $150 with the brunt of the cost being the sheets of oak veneer ply that I was going to use for the tops. I just like the look but you could easily make the top out of whatever you want.
The kit itself consists of the 4 main legs and 6 smaller shelf links and a bag full of 1" screws. The legs/links are made of a nylon plastic and feel quite sturdy to the point that the company advertise up to 1000lb capacity per main shelf with a maximum of 3 shelves.
Assembly was straight forward. The best part about this kit is you can build it as big or small as you like with as much, or as little, bracing as you want.
The kit does have a couple issues though. The lower bracing only has 2 screws per 2x4 which I felt was inadequate. Its plastic though so I simply drilled and zipped in a third. My BIGGEST complaint though is with the provided screws. As stated they're 1" which is far too short to catch the 2x4 through the legs with any real bite. I'd estimate only the last 1/4" is actually hitting wood. I plan to remove all of them, trash them, and replace them with 1-3/4" screws.
The provided screws are also too short for any additional bracing but I keep boxes of deck screws around which I used quite a few of.
All in all for around $225 (added in a slapped on coat of stain and poly) and a few hours of labor I got myself an 8' wide 36" deep work bench. I braced the hell out of the tops to prevent the ply from sagging and plan to further brace a corner to mount a vise. For the moment I left the middle shelf out as im going to put two smaller shelves there so I can store taller items such as my chop saw.
Not complete but this is the current result.
AceofSpad3s
Looks good, probably wouldn't do a ton of beating on it with a hammer though, those screws look a bit short for my taste. Then again I laminated 2 2x4, for each my legs and used 3 1/2 nails, so perhaps I might be tad on the side of overkill.
tarbellb
Oregon
Interesting legs, kinda retro cool, I think :headscrat
But that laminated top is not going to hold up very well to abuse. Protect those edges, they will peel and de-lam quickly, and that top layer of "Oak" is literally paper thin, with a softer mdf/ply core.
Having a large work table is awesome tho, enjoy it.
2000-cvpi
So for about half the cost the one you originally wanted you have a plywood and plastic bench. I’d have just bough the metal one. I’m glad you are happy though.
earlthegoat2
SE GA
If you ever feel you need to beef up the top, gluing and screwing another 3/4” sheet of ply to the top really helps.
seber
Deep East Tx.
I left it behind when I retired but I built mine from BMW and Harley Davidson motorcycle pallets. It made a laminated wood top as well as legs. Those crates are elm and oak respectively. Joints were pinned mortise and tenon. Planing the top was an experience to be sure. But if I had access to the crates I would do it again in a heartbeat.
Skin
Boston
I priced out a bb top at about $200 but I don't plan on beating into this with a hammer. Just wanted the work space and storage room.
Its actually about 80% 2x4 and 2x8s. The pre-made one was also only 1 level (the top). Like I said nearly half the cost was from the oak veneer ply but I liked the look of the grain. Someone could easily build an identical bench with all solid wood or a cheap ply top for quite a bit less.
tapered-pin
Alpharetta, GA
not that there's anything wrong with your workbench..
But there is a huge difference between a plywood top and a butcher block top (stability, heft, durability, etc).
did you look at using some threaded rod and 24ea 2X4s on edge for the work surface?
jimreed2160
Tallahassee FL
Good workbench at a good price. I like the concept and your execution. Best part are the options for the future. With your low investment, you could leave it when you move, take it with you, or remove the legs and take them to start all over.
straightcut
Phoenix, Arizona
How tall is that bench? I like one that when I stand next to it, my forearms are fairly parallel to the ground. I don't want to be bending over to work on something for hours.
I have a few maple butcher block top workbenches and like them. They are very sturdy, especially given that they're 1-3/4" - 2" thick. A home made bench that I have has two 3/4" plywood sheets glued and screwed together, then a layer of Masonite that's had several coats of polyurethane soaked into it. It's a very durable and inexpensive top that is easily replaced should it get damaged. I screw the top to a 2x4 that's been screwed to the wall and runs parallel to the top and front legs are cross braced. I also have 2x4 perimeter bracing on the top. I'd be comfortable putting any weight I would ever need on that bench.
It's pretty easy inexpensive to make something custom to your work space that's the correct height for you.
Skin
Boston
No argument from me but like I said i dont plan to beat on it. I wanted flat otherwise I wouldn't of bothered with the ply at all.
35.5"
Widgeon
Try to find an old solid wood door for a top. If they are demoing an old building or school ask or check the dumpsters. Best cheap work bench top around
Jeff
Sonova Beach
I have 3 of those 2x4 basics bench kits in my shop, right in the middle. Two with 3/4" plywood tops and the other with a Crapsman butcher block I found on clearance.
Don't let anyone fool you. They can take a beating and with 3/4" wood are rated at 1000 pounds.
Elsinore13
I just bought a bunch of metal screw together brackets at the lumber yard, some lumber and a sheet of 3/4 plywood. 20 years later, a contractor left a 2 foot wide piece of cabinet grade ply behind from a job and I snagged it to put a fresh layer on top and to beef it up for a vise.
Elsinore13
Couple pics for above post.
Provincial
Near Salem, OR
I built a workbench from the cut-off from a gluelam beam that was too long for the installation. I got it for free. It is 6" thick, 20" wide (dimensions as installed, the beam is 20" tall, based on the laminations), and nine feet long. I bolted the back end to the wall studs with 2x2x1/4" angle iron brackets and made legs from 1" square tubing for the two front corners. I was going to bolt the front legs to the floor, but in the last 35 years it hasn't budged without doing that!
You can get gluelams for free or a song if they have become even slightly weathered. Once there is any weathering at all, they can't be used in construction. And where else could you use them? Only something non-structural.
Maui
Upstate NY
I just picked up a vintage butcher block top from a local woman with a vise mounted to it for $50. The top measures 3 1/2" thick, 30" wide, and 7 feet long. It apparently belonged to her grandfather. It is quite heavy. I plan to sand it down smooth, and then apply five coats of Tung oil to the surface, lightly sanding between coats. I'll mount it on some heavy duty cast iron lathe legs that I picked up not too long ago. It should make for a very functional and old school looking work bench. And the overall cost will be around $100.
tarbellb
Oregon
Now that I want to see, post pics when you are finished.
