A Little Detailing Garage, UK
sunilbass
Hi Guys
I thought id share my project over this summer...
Ive been on this forum for a while, getting ideas but this is my first post!
I've basically done it all by myself! The only outside trade i caled upon was a roofer and a builder to do the foundations! There is only so much you can do yourself i guess!
As per usual, you can never fit a car into a normal size garage let alone work on it, and building a new one, in brick was too costley just in labour! The size of it is 6m wide by 4.8 length
i started by hiring a digger and having a play! Our garden had a raised area, approx 10m by 10m which needed leveling in which the foundations are going into! But once i started and tried to get all the soil into the skips, which where about 25m away! i called in some builders to do the foundations and groundworkers to get rid of the rest of the soil!
Once the foundations where prepared, i started to make the frame work, all made with 4 x 2 treated timber, this took me one afternoon!
Once the framework was up, i started on the shiplap
I decided to change the main beam where the garage door will be from a timber one to a rsj, for peace of mind as i thought this would flex over a period of time!
I decided to have a couple of small windows in, made at home, total cost 15 each!
Door test fitted!
Started wiring up the electrics
Started on the gutters
Insulation done! just the roof insulation to do!
Gutters all done!
This has taken me a few months to do on and off at weekends, i guess it could be done under a couple if weeks and if theres a few of you, i think it can be done under a week!
Not much left to do! just got to insulate the roof, board and paint the walls, get a sparky in to finsh the wiring, decide and finish the floor and create the loft space! Then landscape the garden!
scorp7
Very nice.
I saw you poured your slab even with the soil. My garage was built that way but I just found that the bottom wood of the walls have all rotted. Is that waterproof membrane you put on yours? I had to replace all bottom wood, installed waterproof membrane along with french drain due to water coming in my garage. What a PITA!!! Though now I have an excuse to remodel : )
Lickers
West Midlands - UK
Always good to see another member from Blighty!
That looks great. Fair play to you for adopting the DIY approach. It certainly appears to a have an excellent standard of finish. I'll look forward to seeing the rest of the build.
Out of interest, what car/s will you be sticking in there?
Nice work Sunil................just one little observation though and not detracting from your brilliant have a go attitude,but the rsj is the wrong way up,it is designed as an *I beam* .The way you have it installed,rotated through 90 degrees an H as opposed to an I(if that makes sense)means it is not actually doing the job it is intended for.You don't have a massive amount of load transferred on to it, as the ridge is pretty much weight free with it,s loading and is therefore not exerting any load on the beam.But for any future little projects(or if you decide to hang an engine hoist from it,you are going to need a re think:)
