A little rail anvil I made.
LuckeyLoser
Toledo
This is one of two I made last year. The other one is larger.
steaks&anvils
Colorado
That is great! Really really great!
We have a thread for railroad rail anvils and a thread for real anvils/RR anvils. Could you post your pictures to one or both of these threads? That way your cool RR anvil will be preserved for posterity! Single small threads tend to fade away, a big thread will last for ages.
58Yeoman
Central IL
A couple months ago, I sold a bench vise to a guy who said he was getting into fabricating and maybe blacksmithing. He asked me if I had anything else that might work for him. I showed him a 54" chunk of rail, and sold it to him for $25. He was happy to get it, and I was happy to get it out of my way.
Jackfre
N CA
LL, that is really nicely done, but exactly how was it done? With that long horn, what work are you intending to do on it. I’m selling my Hay Buden and have an 8’ section of heavy rail I’m going to go after. Have to wait for winter though as I can’t run the grinder outside until it starts raining, if it ever does.
L
LuckeyLoser
Toledo
Band saw right angle grinders sandpaper on said grinders ceramic grit worked the best. Polishing wheels on the grinders to finish. I used different grits to polish and try to remove grinding and sanding finish. I don't ever plan on using it. They adorn my bedroom. My wife has her jewelry and I have mine.
L
LuckeyLoser
Toledo
I took a junky Delta 2 speed bandsaw I got for 10 bucks at an auction from a machine shop they treated it like a pile of trash. I worked on it I replaced everything that it needed to work correctly. Then took the biggest pulley I could fit on the slow speed shaft and one of the smallest pulleys I could find for the motor. Laid that track on it and started sawing. Then hours of grinding, sanding then polishing. It was so much work I can't find any good reason to strike it. So I just look at it. I have a 80 pound section of Crane rail I hammer on.
The other one was mushroomed from excessive use. Never use these for doing what I have done. You will spend countless hours questioning your decisions. Use rail that has a clean top nice and even and you will save hours of your time. H o u r s. The ceramic discs may be the ticket to finish one much faster. I have yet to actually use one from the start. But from my time with one it looks promising.
I still have 9 sections of standard rail. These are much taller and wider than the others. They have a date marking of the 1920s if I remember correctly. The rail has a beautiful even rail crown. They took about a half hour to crosscut.
I made six cuts two on each rail section I had.
nadogail
Coronado, CA
The last time I saw some track replaced the crew loaded the whole rails onto a flat car and replaced them with a long length of continuously welded rail. The replacement rail was not new material, but old rails welded into long lengths.
