A couple more weekends of shop work under my belt. The tight space can really slow things down sometimes, but we have 80 degree weather (!) here in Chicago this whole week and what a pleasure to finally open the windows and shop door.
Last fall I picked up seven department store light fixtures from fellow GJ and OWWM member Eric Clayton and finally was able to understand how to install them in parallel. Took some learning about ampherage and wiring diagrams, but they look great! These are 35w spots and each can be swiveled 360 degrees and adjusted about 15 degreen up/down - so I can point the spots to individual machines and work surfaces. I'm going to keep two or three of my old 4' T8 fixtures as well to light the overall shop. This gives me 408w in my 170sq ft space - so if my math is right it is pulling 3.5amps on a 15a circuit. The outlets above my bench are on a separate circuit.
I built a riser and moved my parts boxes to one end of the shop - will post photos of that later. That gave me about 7' of clean floor space and I lined up my scroll saw, band saw and drill press. I'll be adding casters to these so I can pull them out a little and have plenty of room to work with them.
As you can imagine, the rest of the shop is a complete disaster from shuffling everything - next weekend's project!
It was so incredible out this weekend I spent a good deal of time working on the cabinet of my table saw:
Ready to go - internal parts out and ready for refinishing:
Stripped to the bare metal with an angle grinder and flap wheel. Soaked the feet in evaporust.
Rustoleum self-etching primer is awesome!
Still need another coat, but it looks great from 10 feet away!
Finished the saw assembly a week ago - atteched it to the table top. I will attack the tabletop rust once it is on the saw cabinet.
Won't be long before this baby is ready to go.
