a minimalist toe jack design
metalmagpie
Seattle
I have long considered building a toe jack. Every time I see a posting describing one someone built, I think about it all over again. Today I built one. Mine is *much* lighter duty than most I've seen, and it fits over a tiny old filthy 4-ton hydraulic bottle jack. I don't see why you'd need an 8, 12 or 20 ton bottle jack to lift one end of a lathe or mill. Seems to me 4 tons is plenty. Anyway, I put together a little page. Have a look, and let me know what you think.
metalmagpie
http://www.nwnative.us/Grant/shop articles/toeJack
matt_i
SE Michigan
Looks good, I think a light coat of grease or oil (at the proper time) would save the "bottle" a little longer. One can never have too many rigging "tools" in their possession when it comes to moving machine shop machinery :) I have always wondered if the rod guide bushing of a bottle jack is built (better, worse, about the same) as a standard air or hydraulic cylinder...
Cyberbear
California
This is a clever design that no doubt works well for light loads. The only concern I see is the 1/4" thick toe may bend down if over loaded. A simple pinch bar will get any large machine up high enough so that a 1/2" piece of steel rod or water pipe can be used as a roller. I moved my 2500 lb. SB lathe using these simple methods.
