Last year when I wanted to fabricate some metal and wood furniture, I had to figure out how to cut curves in metal plate. I stumbled across something called a plasma cutter. I had no idea what it was. Then I learned what one could do, and I had to have one, and I wound up with a PrimeWeld Cut60.
View media item 110437
First I needed a plasma cutting table, and so I bought a very inexpensive model from JEGS. I need to move things around my shop, and so I attached plates and casters to the legs. This was my very first stab at welding anything. Ever.
View media item 110422View media item 110423
I also learned that plasma cutting generates a lot of sparks, fumes, and slag. And that's when I jumped down the rabbit hole. The first order of business was to fabricate a sparks and slag collecting system, so I started with a sheet of 18G stainless sheet:
View media item 110424
After much measuring and 3D modeling, I cut the four sides:
View media item 110425
...and, using a new brake, and in my first time welding sheet metal, put together the collecting funnel, which I thought bore remarkable resemblance to a kitchen stove fume hood:
View media item 110426
I attached it with screws, and added an internal bottom shelf of 3/4" ply covered with a piece of 18G SS sheet:
View media item 110428
This is where the project got very difficult for me because I had to modify a commercial table that wasn't designed for modification to turn it into a downdraft table. I enclosed all four sides with mild sheet, cut an opening for a door (to remove the slag bucket), and cut a hole for fume extraction.
View media item 110430View media item 110431View media item 110429View media item 110433
By this point, I was already using the plasma cutter to make all the cuts...to make the table for the plasma cutter. A nice symmetry. After a coat of Rust-Oleum Farm & Implement paint, this project was done:
View media item 110434View media item 110435
Fume extraction is handled by a HF ventilation fan that I installed inline into some 8" ductwork directed out of my shop:
View media item 110436
I made numerous test cuts in everything from 18G sheet to 1/2" mild plate, using the whole surface of the table in some instances, and covering a portion of the table in other instances. In all, the downdraft works perfectly. No fumes in my shop.
