A quickie 1 wall realignment
Steve from Socal
Hutchinson Ks.
I have been doing some repairs that required me to get to the back of my saw and just getting the dog house off was a struggle. The first pic is the original set up, the next is after removing my drill press, arbor press and belt sander. I blocked the saw and used the porta-power to push the lathe about 30" The small tools on the shelf were not in a good place to work any way and it cleans up the area.
Steve
sgtusmc
Steve, That's some serious equipment you have. It looks as if it fit's kinda tight there. I have some extra room in my garage...that's if you don't mind me use'n it:rocker:
Falcon67
Merkel, TX
Nice - senior level equipment there. Is that a jumbo phase converter hanging on the wall? It's amazing how sometimes just moving a couple of things makes it so much better or frees up space. I seldom have such flashes :D I'm putting my heavy equipment on fabricated leveling platforms with rollers. When I got my mill/drill I built a stand that would let me level it and move it on casters by taking up the leveler feet. Going to do that with the lathe bench too.
Steve from Socal
Hutchinson Ks.
I had been pondering what to do for a week, I would like to move that box to the side wall. The box is a DC motor drive for the lathe. The problem with moving the box is adding to around 40 wires and 2"liquid tight flex conduit. I suppose I could run a section of rigid across the back. The tether on it now is at the limit. I have a phase converter out of sight, just a 5HP motor with a few caps and relays. It is amazing how shuffling a few things makes a world of difference:)
Steve
Steve
Falcon67
Merkel, TX
Ah - DC controller, much more complicated. Yes - a cable tray would work for that I'd think, then you could put the box somewhere else. But if it has the E-stop on it, you might not want it that far off. My mill's three phase control takes up much less space:
