Marctrees
I would like to have a very accurate "Framing square"
Let's call it a "Patternmaker's Tool and Die Makers Big *** Square"
More or less, more even better, just like every Carp has, 16" and 24" legs, or longer, BUT accurate enough to use to set up virtually perfect as possible furniture making jigs.
Would be babied, never tossed around.
Only occasional in shop bench use, by me alone kind of thing.
I'm not totally nuts, ( at least not yet diagnosed ) and an off the shelf $15 may be sufficient... so maybe the real question here is... HOW do I confirm it is how accurate?
I suppose I can check the individual legs for sufficient straightness, but HOW to check how accurate the 90 is at the end of legs?
Maybe I am OCD, and the flip test should be good enough, along a confirmed straight edge, with a sharp razor scribe, or something like that.
I just learned through experience years ago, that if stuff is not made as accurate as possible, errors may very possibly add up.
What do you Machinist type accuracy nut guys think ? Marc
