A Tale of Two Compressors
Roberts210
Missouri
So I got hired last Fall to do the windows on a rebuild of a craftsman Streamline Moderne house out in Cal.
I left my old C-H compressor at my farm, figuring I could pick up a decent one on the L.A. Craigslist. And when I got out here in Oct. I found this one. It’s a Craftsman 3 H.P. (Hahahaha… sure it’s 3 H.P! In their dreams!) However, being familiar with Craftsman’s rating system I figured it would perform OK.
I bought it out of a rental yard, so I knew it had had a rough life, but for $80 I figured it might last the winter.
The only thing was it had a really nasty “chuffing” which I tried to ignore, but eventually tracked the sound down to the fact that an intake flapper valve was broken.
I only discovered that last Friday and ran around the S.F. Valley trying to find a set of replacement valves.
Grainger didn’t have anything, and neither did a nearby Industrial Supply, but Grainger guy pointed me to All Air Mechanical and Engineering, which happened to be a place that sold and repaired and serviced air compressors. This place was heaven if you love air compressors. They had everything from huge rotary compressors bigger than a VW bus, to little 20-gallon units like mine. He had the valves in stock and I got ‘em. Went back to the jobsite and started in on the compressor. There was a lot of what can only be described as gunk on the old valves and inside the head. I wire brushed it off and replaced the valves and then realized I should probably pull the top plate off and inspect the other set of valves. That set checked out OK, and I found the remains of the broken flapper valve lying on top of one of the pistons, but in pulling the top plate I tore up that gasket. So back to All Air to see if he had a gasket. He didn’t, but he showed me a Speedaire 20-gallon compressor that a previous customer had abandoned there 8 months ago. Said it was for sale and was I interested? I told him I’d get back to him. I eventually solved the gasket problem by cutting my own gasket from some stuff I got at the auto parts store and I got my old red Craftsman up and running. She ran good all Friday afternoon. But I couldn’t get that pretty Speedaire out of my mind. So Friday night I put the Craftsman on the L.A. Craigslist for $100, sold it on Sat. morning and on Monday I went and picked up the Speedaire. Got it for $127. Love it.
Interestingly enough, the guy at All Air said all the gunk on the valves and head of the C-man was residue from the previous owner running automotive oil in the compressor for an extended length of time instead of non-detergent oil or compressor oil. Seems the additives in detergent automotive oil also allow it to dry out and harden into varnish a lot faster than non-detergent oil. The heat and constant air flow over the oil droplets hastens this process. So, it's compressor oil for me from now on.
R
Roberts210
Missouri
Thanks Zeeman. On this job I'm just running a needle scaler and a air chisel, but later I'll use my trusty old Hitachi NR83.
R
Roberts210
Missouri
It's MUCH better. It's quieter and the actual compression unit is USA cast iron, while the C-man was cast aluminum. The gauges in the C-man had no glass in them, and I wasn't sure they were completely accurate, but I have no doubts the Speedaire gauges are correct, and they appear new. The Speedaire tank seems of a heavier gauge, and it has a depression on the bottom at the drain valve, so water can collect there before getting forced out the valve.
softailgarage
Bullhead City, Az.
Good story. I'm curious as to how much better the speed aire performs and how long the craftsman lasts. You sure couldn't beat the deal you set up.
Sent from my SM-N915V using Tapatalk
nic6paul
How well does that speedaire keep up with the needle scaler? I have a similar compressor and I would like to use one as well.
