mybigwarwagon
or really bad shoulders.If you do that metaphorically and hurt yourself we have some serious problems.![]()
The bonus is that getting the neighbor to help is a huge plus. He's 80+, and he absolutely loves helping out on little jobs like this. Low risk, easy for the two tractors. Also makes asking for favors from him easier. And I hope we don't have any more stumps to pull. I really don't like dropping trees, especially live ones.Stumps can be a real PITA, they are almost always heavier than you think, I like the idea of the pressure washer though. The roots really hold a lot of dirt and that will substantially lighten things up for sure. You could try a two part cable, use the GF as the anchor, it is probably much easier to borrow the bigger tractor, but for future stumps.![]()
Thanks for dropping by tls1. Yeah, if I had to do it over again, we'd do it differently. We pulled about 20 stumps, and this was the only one we had issues with. When I tried to pull it over with the Mini-Ex or the Old Mule, it literally didn't shake, even the littlest bit. Too much clay around the tap root. Remove clay, and get movement. A dozen yanks after that, and it popped loose.if you had a rental excavator, the best way to remove stumps is to leave the the rest of tree attached. Dig around stump with mini-ex and push it over. I have take 50+ trees that way on my land.
Plows and hard objects below grade don't get along. I am fairly certain that he is clearing to plant more.Just wondering, could stump stayed? Trim down to below grade?
It wouldn't make a very good killing device. It doesn't like twigs that are bigger than a #2 pencil.Good point
I have one of “those” stumps too.
You know you want a basement... eventually.and I don't want a void, even if it is small, under the shop floor.
Like the picture in the WTF thread of a garage in NJ (I think) where they got up in the morning and their BMW was sitting in an 6' deep hole? But what I want is irrelevant. This will be for SWMBO. She says no basement, no pit.
It's funny you say that. Robin watches a weekly hemp show put on by the hemp people here in Michigan. She asked me to watch one because the guest was pretty interesting (and he was very much so). One of the regulars on the show was so high someone could have used him for a satellite.I think I just figured out an entirely new industry that can be started. You know how people buy 0% alcohol beer, why not sell 0% THC weed, you get all the taste, but none of the buzz, that way people can smoke it all the time and not become complete morons. Of course I wouldn’t use the term morons in the marketing campaign.
Considering how old we are and the fact its a northern car, Id say you had a very productive weekend. Looks like you moved faster than I did.I thought you would appreciate what doing this with an old Wi car entailed this weekend. Friday I put up the temporary summer shelter and moved the crawler (fired right up!) under it. Saturday a complete, running, driving parts car was driven in and this is where I got to this aft.
Between the rust and my age, I'm not as fast as I used to be...
Sounds really familiar, like an echo. Were the studs snapped flush? If there's a bit of a stud left, heat the manifold red hot, put an undersized nut on the stud, using an impact in reverse, push against it and it should walk right outNow I'm following in your footsteps, and I'm not liking it.
Pulled the trans off the motor today and discovered a cracked exhaust manifold. Rustiest exhaust bolts (Olds used bolts) I've ever seen. Through some miracle and Kroil, I got all 5 drivers side off. The 9/16's were rusted down to 13 and 14mm.
Turns out the rearmost passenger side bolt is broken off too. Front broke off on me immediately. Three in the middle were rusted down to 1/2 but came out.
So I end the day with 2 broken off exhaust studs that need removing.
I'm gonna order an oil pan and valve cover gasket set for it. Sounds familiar, I bet.
.I'm surprise you don't have torches with all of the old stuff you work on. I probably use mine 3-4 times a year, but when I do, they're a life saver.Not something you want to take apart every year, so I agree with all new and be done. Especially the way you tow while hauling dirt.
Unfortunately I have never invested in a hot wrench, so Kroil and time will hopefully get my exhaust studs out. There's a solid 1/2" sticking out, so what I usually do is cut two flats in the end and use a small wrench after the kroil bath. If the wrench rounds a bit, I fall back to the vise grips.
Nothing. He had it capped off at the flex line. Can't say as I blame them, there's only 1/2" between the backing plate and the u-bolts. In order to bleed everything, I left the backing plates flopping around and put a ratchet strap around the shoes to get to the bleeders. The other thing that necessitated the job was that 2 of the wheel studs on the passenger side were rolling around inside the rear drum. The hub on that side was worn out, as were all of the studs.Good job!
You mean there was no brake line at all on the left side?
It was pretty loud. Beat the backing plate pretty good. Ended up having to replace one of the hubs because of the studs.You are making me feel like a slacker, I have to do this on one of the burbs and it is not a full floater, so it is way easier to do, still haven’t done it.
those studs must have made some interesting noises inside there.
