partsproduction
Many years ago I added a quick detach vise mount to my bench, the bench is all steel and the vise is the Wilton 6" Offset vise which we use daily. I'd read long ago that common wisdom for mounting vises is that the top of the jaws should be at or very near the elbow height of the person using it, this being because a standard use of most vises is filing parts with a hand file.
The first photo is of my employee standing next to the vise, you can see that his elbow is at about the right height.
Below see the overview of the installation, I laid towels on areas that would otherwise clutter the main elements, you can see that the vise is bolted to a bracket, which is welded to a length of heavy wall square tubing;
Here is a view of the inner 2" square tube slide which is pulled out of the larger square receiving tube. The receiving tube is stoutly welded to the bench's frame;
More,,,
More,,,
