-Trammel points were/are commonly used for layout work by (machinists, sheet metal, wood workers, etc.) scribing thin lines on surfaces. Creating reference points or geometric shapes (half-way location, perpendicular lines, tangency points, etc.) can often be done without measuring. They're very handy for point-to-point measuring (center-to-center or edge) minimal weight, and can use whatever shape/length contact probe as needed. Need more/less length? Use a different beam. They're often cheap and often only limited by your imagination.Didn't know there were fancier versions.
I used to have a set of stair stops for my steel lay-out square that could also take points. Uber handy!-Trammel points were/are commonly used for layout work by (machinists, sheet metal, wood workers, etc.) scribing thin lines on surfaces. Creating reference points or geometric shapes (half-way location, perpendicular lines, tangency points, etc.) can often be done without measuring. They're very handy for point-to-point measuring (center-to-center or edge) minimal weight, and can use whatever shape/length contact probe as needed. Need more/less length? Use a different beam. They're often cheap and often only limited by your imagination.
-Necessity is .......Usually two nails and a two-by, but sometimes for a pencil or saw.
And the two by was still usable as construction lumber.-Necessity is .......
I suppose a couple of plastic wire staples would work too.I used to have a set of stair stops for my steel lay-out square that could also take points. Uber handy!
I can't count the number of field-expedient trammels I've made on the jobsite. Usually two nails and a two-by, but sometimes for a pencil or saw. Need to trim a 24' radius arc on a round deck? No problemo.
