TNToy
Got back last night from vacation (gone 5 days), to a cold house, a weird buzzing sound, a horrible burning smell, and a really hot blower motor.
Killed the power to it, pulled the cover, and touched the blower motor. Hot! According to my programmable thermostat, the unit "ran" for 23h 37m the previous day, so it was probably doing this for quite a while.
This is an old (original, home built in '74-76) heat-pump style unit with emergency heat strips. Everything is running correctly, except that the blower motor just produces a very loud hum/buzz when it's powered up. The evaporator is getting hot to the touch, and the compressor can be heard running outside. So it's fine, except that it isn't moving any air.
When we got home, I got it to run by pulling the cover, turning the thermostat back on, and spinning the fan by hand to give it a push-start. It sloooowly spun up to speed, and proceeded to start up just fine the next half-dozen cycles of the unit. Went to bed, and at 4 AM I was awoken by the buzzing noise again...
But now spinning it over by hand won't help, and I'm tired of it being 61 degrees in here, although I'm glad that I live in the south, so it's not -20 outside. I checked it over for loose wires, and basic obvious visual stuff, since I know nothing about HVAC. Found a bad crimp on the black wire running to the motor, but re-crimping it made zero difference.
Any help?
Any help?
