Careful, I'm pretty sure that's the OP's video.I actually watched the video. Guy had the wrench oriented the wrong way for the direction he is turned it.
That has been tested and it really doesn't matter which way you use an adjustable.I actually watched the video. Guy had the wrench oriented the wrong way for the direction he is turned it.
Who tested it?That has been tested and it really doesn't matter which way you use an adjustable.
https://www.garagejournal.com/forum/threads/crescent-wrench-directional-arrow.467179/
The only person I know of is tubalcain aka mrpete222 on youtube.Who tested it?
For the use in the video posted, sure, it doesn't make a difference.
I've used them the "wrong" way and the "right" way as well, you can get away with it many times either way.
If I'm loosening or tightening up some angle stops on a compression fitting using two adjustable wrenches, you can rest assured they're both orientated the "right" way.
I have two of the "Park ". Added them to the order I made a while ago. They don't say Park anywhere on the wrench. They're worth a buck for sure, saves a trip to the garage. They're not great quality though. I played with one and the fixed jaw got a little dent in it when I used it@Jeff
Thanks for the pics and video.
Looks decent for a cheap one.
Fair warning: those 4" adjustables are contagious!
If anyone buys from Park Tool, they have a generic one on clearance for $1.00.
https://www.parktool.com/en-us/product/4-inch-adjustable-wrench-paw-4
If you buy 75 of them, you'll get free shipping.![]()
I watched some parts of those. Seems he's doing destructive testing of the wrenchesThe only person I know of is tubalcain aka mrpete222 on youtube.
No matter which way you use one the forces are trying to push the two jaws apart, the forces have to equal, its basic physics.The idea I think is to put downward rather than upward force on the movable jaw. Allows friction to hold some of the force instead of all going onto the wrench's knurl.
I think the wrench works best when about half way open from closed. Not so good when the wrench is used on something so big that it is all of the way or at least most of the way opened up. Time to go get a bigger one (or better yet a proper fitting WrightGrip combo or a Williams Superwrench.
Right or wrong way doesn't make much difference on low torque situations like turning an already "broken loose" nut
Used to take off the 15/16" nuts that secure the blade on "Craftsman" lawn mowers with (?) 8" adjustable before I was old enough to know better
miss the Sears with its tool dept. that used to be in walking distance from when I was about 10 years old
Do you have a favorite?I've got a couple 4 inchers. Love the tiny tools.
It's not just force though, it's also moment about the base of the beam (jaw). As mentioned, having the reaction force at the tip of the moveable jaw allows friction to help lock it in place, reducing load on the rack/worm. And the fixed jaw is skeletonized about its base, so limiting moment there helps as well.No matter which way you use one the forces are trying to push the two jaws apart, the forces have to equal, its basic physics.
Nice. The 12pt broach in that one is unique.
