I have a small panel box with about 10 spaces in the garage, which is fed from the main 150 amp panel. This is all in one building, wire runs inside, dont know if that matters. There is a 50 amp breaker in the main feeding the "sub" panel (not sure if its a sub panel being in the same bldg?? I dont know alot about electric) Its fed with #6 cable, alum, there are 4 wires.
Now, my question. I have a brand new "Homeline" panel box with a 100 amp breaker in it, the breaker appears to be "fixed" in it, not removable like a normal breaker. Is there a way to remove it and install a 50 amp breaker in it? Also, does this 50 amp panel box have to be bonded, or should it not be bonded? I do not understand what that really does and why sometimes its done, and other times its not.
I am going to run the 50 amps until I run larger cable from the 150 amp box, unless I decide I dont need all of that, but I do have a Lincoln Ideal Arc 250 welder, and Lincoln Square Wave 175 Tig welder, Im not sure of the amps they are rated for. Thanks guys
Craig
Craig
