Mark100
My garage foundation is complete and I am using 2" eps panels to insulate the outside of the concrete wall. The foam is currently all the way up to the top of the poured wall. Final grading will leave 16 to 6 inches of exposed foam around the perimeter.
I am debating on cutting the foam at grade and leaving the 8" thick wall exposed vs. Leaving the foam in place and coating or covering it with a material and drop edge while siding.
If I cut the foam out, will this be a huge mistake with regard to insulating the building? I dont want to place insulation on the wall inside the building. I plan to heat the building during the winter and the walls and ceiling will be heavily insulated.
Mark
Sent from my SM-G960U using The Garage Journal mobile app
Mark
