bob15
Going to helping my Brother with his above ground swimming pool.
The pump is 2 hp, 115v
Distance from main circuit panel to where he wants to go out of the house is between 80-100 ft
Distance from house to pool ~25 ft max
One thought was to run 6/2 w/ground romex from circuit panel to about where the hole will be for going out of the house, add a junction box and run liquidtite from box, through wall, underground to GFCI outlet 6 ft from the pool. Inside the liquidtite would be three 6ga THWN wire.
My question is: if the 6 gauge inside the conduit needed, how do I install it onto a outlet? Buy a double gang box (for the working room) and pigtail the 6ga to stubby 12 ga and attach the 12ga to the outlet?
Or would running liquidtite and the THWN wire from the circuit panel to the pump outlet be a better option?
