This is an interesting product designed for compressed air systems. It does have limitations which you should be aware prior to installing it in your shop. Take the manufacturers recommendations and warnings seriously and make an informed decision.
From the manufacturers technical specification:
Clean air required:
Air-Line is ideally suited to clean air applications.
Where air is not free from oil, IPEX must be consulted prior
to installation concerning the suitability of the compressor
oils to be used.
Note that synthetic oils are generally not compatible
with Air-Line and must not be used with the system.
Certain additive rich mineral oils are also incompatible
with the system.
As a safeguard, IPEX has produced oil warning labels for
attachment to the compressor. These are available upon
request.
Call before using oil in lines:
WARNING
Certain compressor and lubricating oils will damage
your Duraplus Air-Line installation
Before using any oils in the system, contact IPEX
to obtain a list of recommended oils or to confirm
individual oil suitability
Exposure to sunlight requires painting:
Care should be taken to avoid prolonged exposure to
sunlight, which will cause discolouration of the Air-Line
Xtra material. If stored outdoors, products must be
underneath an opaque covering, e.g. a tarpaulin.
If installed in a location exposed to sunlight, the
pipework should be painted
Pressure temperature restrictions:
Compressed air temperature at 120 F limits air pressure to 115 PSIG.
Link to the manufacturers technical specification:
https://www.aetnaplastics.com/site_...etnaproduct/67/Duraplus Air Line System_1.pdf
