WhoWhatNow
I need some help troubleshooting the ABS system in my 1991 BMW 325i (e30). The symptom is a constant ABS light on. I have a late model car, so it does not have the fusible link in the relay under the dash which seems to be a common problem with these cars. I pulled both relays in the ABS pump and tested resistance between 85 and 86. Resistance was 57 and 49 ohms for the two relays. That is the extent of my abilities to diagnose this issue.
I would like to learn how to diagnose electrical issues on cars, however knowledge of electronics is limited. Can someone help with detailed steps I should go through for a proper diagnosis? I know my way around a multimeter, but I don’t always know where to pick up a ground or how to apply power to a circuit for testing. Basically can you explain it like I was a 12 year old?
