This is for a mini split. I mounted it on an interior wall so a little pvc plumbing is needed. Normally they just wanted you to run the drain hose to the yard by gravity.
I was wondering since I am doing the plumbing and I will place the hose into the piping. do I need to add a WYE and maybe drill a small hole for vent?
I have put a bucket and the unit would put a batch of water once in a while instead of a continuous drip. It scared me a bit.
Anyway I think either way it would drain since the pipe is bigger than the hose. Just wondering if adding a vent would be quieter plus it can be removed for cleaning out. However a wye fitting needs to be special order online, plus I don't want the air infiltration if this isn't needed. i could also clean the pipe from the AC side.
