AC Condenser Replacement.
OldCarGuy
Three weeks ago my 15 year-old R22 house AC condenser compressor died. Having insight, ten years ago I snagged a new Carrier 4-ton replacement at a bargain price $300.00. It's a nitrogen charged unit designed to run on R22 that's 3-phase. Best of all, refrigerant isn't an issue—I have a 200-pound stash of R22 ready to go. Since running 3-phase power from my garage machine shop wasn't practical. I picked up a Phase Perfect 3-phase converter.
Old unit
New unit..
New unit has 40% more fin surface area. Plus it has copper condenser tubes for better efficiency..
f36b1355-738a-4b0d-9f08-57dac279e056.jpge
We begin by recovering the R-22 refrigerant. Please note, this project requires a Section 608 certification. Once the refrigerant is removed, the old condenser is disconnected and the new unit set into its' place. Rather than replace the copper line set, I flushed the lines using nitrogen with Matercool solvent. Note: need to disconnect lines to the evaporator coil.
Control board has an LED that indicated if the phase is correct, without putting power to the compressor.
Phase Perfect 3-Phase Converter with optional outside weather hood. I have a larger rain hood ordered for more protection..
Installing a new dryer to the pressure side. Along with a acid filter dryer to the suction side. In case anything foreign is left behind. Pulled a vacuum with my vintage Robinair pump. Followed by weighing in a fresh batch of Freon.
I have 20 pounds R22 left in this bottle. Along with three full 50 pounders and a full 30 pound bottle with red dye.
My stash also includes of three 30 pounders of R12 for my antique cars..
Plus Two 30 pounders of R134A and a dozen 12 ounce cans for my modern cars.
Jeepster04
How many years ago did you stash away the refrigerant?
I have 2 30lb jugs of R134a and I'm starting to think it wont be enough. Unfortunately that stuff has skyrocketed in price.
fitter30
Peace Valley,mo
Just remember with a two pole contactor one leg will be hot all the time power is on. Also good time to check blower and evap coil for cleanliness. If coil as a expansion valve check the bulb for tightness on the line and insulate it.
O
OldCarGuy
I was quick to see how regulations was going to force major increases in Freon in 1980. And purchased both R12 and R22 in large quantities. At a cost of $.40 per pound. Since R134a was being phase out I have stocked up on it and have invested $2.00 a pound. Like money in the bank...
atikovi
Suburban Washington DC
Except that low cost alternatives come out to meet demand.
PoorUB
Fargo, ND
Hang on long enough and the R12 should become worthless as the demand for it dries up.
I worked for a HVAC wholesaler and we had a couple jugs of R12 that were opened. We sold R12 buy the pound. Weight the jug when it left and weigh in when it came back and charge the customer the difference. We charged $30 a pound which is a high price when you figure you could buy the small cans for under $1 about the time the EPA restricted it. But I worked for that company for ten years and we might have sold 10-15 pounds in that time. Yeah, we were getting rich off of it! :ROFLMAO:
R22 is headed that direction too. If I had a bunch of R22 on hand I probably would have sold it roughly 5 years ago. It has gone own in price and demand since. The company I used to work for would order maybe 1,000 jugs at a time, right before COVID. They would sell it off in a few weeks at close to $1,000 a jug. Today they stock maybe 50 - 100 drums of it and it has dropped in price to less than half of the high price.
O
OldCarGuy
It's a 3phase power and has two contact relay, leaving a hot wire. Some of the single phase units that I've worked had double contacts and some single.. I'm used to working on 480 volt three phase industrial equipment that always has triple contact relays..
Everything is tight and lines are well insulated. It's a brand new condenser unit, as seen in pictures.. And I did a thorough job cleaning the furnace evaporator coils...
fitter30
Peace Valley,mo
Retired 14 years probably 10 years before that two pole contactors were normal for 480 vac 3 phase, 240 and 208. Before i retired went to service call 480/3. Customer had a bad condenser fan motor phase two pole contactor told me i couldn't shut the unit down under any circumstance I left. Three hours after got a call from another serviceman with the same company as me. He got there when the ambulance was leaving. Serviceman from another company was electrocuted dead. Hope the plant manager was fired. Motor was change with the power off.
O
OldCarGuy
I'm sure you're right about refrigerant pricing dropping. As far as R12, I own six old cars that still use it. And five systems using R22.. Furthermore I only have $.40 per pound invested in both R12 and R22.
