I've decided to go with a mini split for my room. I am in the planning stages right now. The new condenser unit I plan to get requires 208-230v, 15amps. Where I plan to mount the unit on the wall, within 5FT, there is a disconnect switch for the sprinkler pump. Inside the existing disconnect, there are two 10 gauge black wires, two 30amp time delay fuses. One side of that disconnect box then goes to the main service disconnect.(1FT distance) Currently the sprinkler pump is disconnected. The other side of the disconnect has three wires. Two black and one green. The easy way out would be to use those same wires to the new condenser, but eventually the sprinkler will be fixed. Once the ac on this side is done, I'll have more questions for the other split unit on the other side of the house.
I can run wires without getting electrocuted and I can follow instructions. I will also pull permits for the AC install.
What's the best way to go?
