AC disconnect pull out vs switch
tny
Minnesota
I am planning the installation of an AC disconnect for a mini split. Is there an advantage one way or another between plain pullout and switch?
Currently I am looking at the EATON QO200TR as a switch option. Comments?
Also, the wire will be NM-B 10/2. What is the best wire connector to go through the wall (OSB+sidding) in a weather proof way for very cold/windy weather?
Any comments or tips will be appreciated.
T
tny
Minnesota
Pull outs are cheaper !
Is that the only point? The one I linked to is $18, so it will nor break the bank...
Caulk the hole after the wire is in place.
Sure, once all in place, I will caulk from behind, as the garage wall, for now, is still open on the back. How do you secure the wire? if it was a metal box inside, I would use the common wire clamp with the two screws, but that will not work here.
Norcal
I like safety switches better but a pull out type disco is way more economical, fewer exposed live parts too.
Stuart in MN
Minneapolis
Nothing wrong with the pull out type. It's not like you have to use it very often - in my case, it's only used once a year during spring maintenance.
Terry D
St. Louis, MO.
I usually stub a small piece of 1/2 inch conduit out the back of the disconnect to just inside the house. It acts like a sleeve for the NM-b, makes it more water tite and still can usually get a staple close enough to secure the wire.
The Square D type disconnect that you linked does not have as much room inside for wiring as others.
yatg
Southern Oregon
The disconnects are nice because you don't have an extra part, the pullout piece, to fiddle with. A switch doesn't get misplaced or dropped or stepped on or kicked under the bushes. Check Home Depot, at mine its $14 for the QO and $10.50 for a GE pullout.
the pullout disconnect can also be flipped and reinstalled which will not turn power back on to the unit. then a lock can be placed on the pullout box. this prevents the pullout plastic piece from getting lost... :D
sparky 1971
Central Iowa
I prefer to pull out type. I am another that stubs a short piece of pvc through the wall. Mark the hole, drill the hole, put a thick bead of silicone around it then install the disconnect.
T
tny
Minnesota
That will work for me.
I understand. It will be 10/2... will it be that bad?
I have siding with a bit more that 7" board exposed. The QO above wil fit flush i one board, wich I think would be neater. In the pull out kind, I have found the MIDWEST U065P, about the same size. Locally I could get the Eaton ACD60RP in thermoplastic, but I would prefer steel.
Terry D
St. Louis, MO.
10/2 will slide right in that 1/2 inch pvc stub
walta
Dutzow Missouri
I wish I had gotten one like this with a GFIC outlet.
Walta
65ranchero
Danville, VT left NJ forever
Norcal
Walta
Code prohibits the GFCI being connected to the load side of the disconnect, just a FYI.
ROBZ71LM7
Louisville, KY
Pullouts are fine. I personally stub a 1/2" PVC conduit through the wall and brick for added protection, although a lot I see around here the romex just goes through with no protection. This seems to vary by jurisdiction and inspector's preference. My home's A/C is 10/2 NM through a hole in the brick (home builder) and my garage's mini-split's feed is protected 1/2" PVC conduit which I installed myself.
T
tny
Minnesota
Walta
I looked into those and similar, but first, I have a receptacle inside the garage, about 12' distance from where the AC unit will be, and second, the disconnect wil be exposed to snow drifting upwards from down hill, which makes the opening under problematic. It would have been easy to wire the receptacle because there is a circuit just behind, but decided not to.
