AC disconnect service outlet
mrVanagon
Belleville, IL, USA
Hello all,
I have a small business installing and servicing low-voltage landscape lighting systems. A friend of mine wants me to help install a new system at his house. The logical spot for a transformer is near the AC compressor on the side of the house but there are no outlets near by. The AC disconnect box has a 20A GFCI in it but that is clearly not meant to have a device plugged into it all the time as the cover cannot close with something plugged in. The easiest thing to do is to drop a short conduit from a KO on the bottom of the disconnect and mount an outdoor box just below the disconnect with an outlet and in-use cover then mount the transformer next to that.
Would this be compliant with code or can that service outlet not also power other down-stream outlets. I've read about the requirements for a service outlet within 25' of the AC but I haven't seen anything about using that outlet as a source for other devices.
Thanks for any input.
walta
Dutzow Missouri
Just to be 100% clear unless you happen to be a licensed electrician in the town where your friend lives it would be a code violation to move or modify the outlet in any way.
Seems to me if you are going to be in the low-voltage landscape lighting systems business most every job you look at we have a similar problem of no outlet where you want/ need it. You need to draw a bright line in your mind that you do not work on 120-volt circuits. If you let yourself do even the smallest 120 volt work it will become a slippery slope and it will become the norm for every job to do illegal electrical work. What happens if somehow someone gets a shock from a 120-volt circuit you messed with? There is no insurance policy to cover you for doing unlicensed electrician.
As a professional low-voltage landscape lighting installer you should be aware that connecting your system to any extension cord is a code violation.
As a professional low-voltage landscape lighting installer I have to ask have you purchased business liability insurance?
If your friend decided to install second GFIC outlet with a cover for your lights that would be great but I think it would be foolish to do unlicensed electrical work in exchange for money.
As I recall the requirement was that there must be a GFIC outlet within 25 feet of the AC unit. Would it be possible to get the appropriate cover installed?
Walta
Walta
ummm you are aware that many states allow licensed contractors to do ancillary work outside their license?
mrVanagon
Belleville, IL, USA
Thanks for the input all, especially the code clarification. For anyone concerned, I have a legitimate business, am fully insured and also understand the license requirements in my work area. Any work that requires permits or licensing that I don't have will be done by someone else before my work starts. It is almost always possible to place a transformer next to an existing outlet. In the rare cases that it is not, the client is required to work that out on their own.
nadogail
Coronado, CA
Because Codes and Permitting Requirements vary by location you may or may not be able to avoid any interaction with your local Authority having jurisdiction.
mrVanagon
Belleville, IL, USA
That makes sense but the current outlet is inside the disconnect box so changing the cover isn't really possible. I think the quickest way to get an outlet with an in-use cover is to tap off the disconnect and add an outlet box beneath it.
mike93lx
Richmond, VA
The outlet near my a/c's is on a circuit with a bunch of other outlets, which I bet is more common than one built into the disconnect. It's just an exterior outlet placed near the a/c's.
I'd go out the side rather than down. Just in case any water gets in the disconnect, it wont drain right to the new outlet
