fabjunkie
Planning out the new shop since we're moving after finishing my 30x40 that I had built last summer. The new shop will be 36x50x12, maybe 40x50 if I can swing it. Roof is 4/12 pitch so it has a 18' peak. I've been working on the layout in CAD trying to figure out where everything will go and I'm trying to come up with a resolution to a mistake I made on the 30x40, ventilation.
This time around there will be a 18x10 drum door on the 50' side, with a man door next to it. On one end there will be a loft 10' out from the gable end with a 7.5' ceiling underneath. The options I've come up with so far are:
1. Windows. Thinking about six 4020 or 4030 side sliders. Two on the gable end opposite the loft spaced evenly across the wall, bottom of the windows will be 5-6' from the floor. Two more at the same place under the loft, and two more above the loft approximately 2.5-3' from the floor of the loft. I would tint them and build interior bars for security reasons. Cost ~$600
2. AC/Heat unit. From what I can gather I would need a 3.5-4 ton unit. I would do the install myself including duct work, etc. Benefit would be I would have heat in the winter as well. This would eat up real estate inside and probably run ~$5-7k I'm guessing.
3. Windows as described above with a small roll up door strategically placed somewhere else in the shop just for cross ventilation reasons.
I'm east of the Dallas area and we really don't get spring or fall, just summer and not summer with a couple weeks to a couple months of cold in the winter. I have a couple 56" or 60" commercial fans that I took out of the current shop that I will put back up. With windows I thought about maybe putting a couple more in the back wall of the shop for more cross routes for breeze. The back wall will be facing South with the roll up door facing North (opposite of what I would think would be ideal.
As far as heat I currently have a torpedo heater that does fairly well making it comfortable, and have thought about a waste oil system as well. This would of course be instead of the AC/Heat system.
I will be doing primarily auto/metal fab work in here with a plasma table running at times as well, hopefully more often than not. Not all day most days, but I want to make it comfortable on the days that I am in there all day in the hot months which is realistically half the year.
Pic of the current layout I'm leaning towards.
Gable end with the loft and windows laid out. 4030 and 4020 respectively.
And the fans that will be going up in the new shop.
Thoughts, regrets, things you did that you appreciate on those hot days would all be appreciated.
