AC saga
dwasifar
Not an HVAC guy by any stretch, but I don't mind trying to figure things out, so here's the story.
My second floor AC stopped working just as the weather got warm here in northern IL. It would run a bit and then shut down before making any difference. No codes showing on the blinking LED from the furnace board. I thought maybe it had something to do with the Amazon thermostat, so I thought I'd replace it with a regular thermostat as a test. Because it used a C-wire adapter, I opened the furnace panel to unhook that, and was greeted by a burny smell. Huh. I remembered smelling that through the vents when the AC came on for the first time this season.
I thought initially it was the control board. I saw a resistor that looked like it was heating up. Tried running the system and yes, the resistor was getting hot. So I thought, well, I don't have to have the board to run the fan. I disconnected the blower motor from the board and rigged up a plug-in power cord to run the fan directly, figuring I could at least bring cool air up from the basement. The blower ran for about 10 minutes and then turned itself off, same burny smell. Aha! It's not the board, it's the blower motor. Some sort of internal fault, it's heating up inside and tripping its thermal protection.
So I sourced a blower motor from Amazon. Was supposed to be here Wednesday, then late Tuesday it got unexpectedly updated to Friday (today). So I ordered another motor, not an exact match (three speeds instead of four, different wiring color codes), to arrive earlier. It got here yesterday, but as it happens the nights have been cool, so I decided to wait for the first motor (the exact part) to get here. Was supposed to be here today. At 8am it left Hebron, KY and I don't think it's going to be here on time.
In the meantime, I pulled new 18/5 thermostat wire up to the second floor thermostat (builder put it in conduit from the basement to the attic, loose in the attic, and conduit from attic to thermostat location, so it was fairly easy), so I can disconnect that C-wire adapter. Which motor I install is going to depend on how much more delay in the delivery. I also ordered a new control board because that hot resistor worries me, but I haven't decided whether to install it immediately or wait for the existing one to fail.
Ohmthis
Outside of Louisville KY
The fan motor, it’s HP rating, it’s rpm, and its speed taps are critical for how the AC/heat work correctly. Just throwing any old motor on isn’t ideal. Did you get a new capacitor too? I’m all for someone trying to fix their own equipment. Be sure to ask or research before just buying parts.
D
dwasifar
Of course I researched. I'm all about research. It wasn't a random purchase.
Both motors were sold as a replacement for the specific OEM Carrier part number. Same rpm, same HP. The difference was that one has the same wiring color codes as OEM and four speeds, (HI, MED-HI, MED-LO, LO) and the other has different colors and three speeds (HI, MED, LO).
The furnace schematic shows the original motor connected to HI for cooling and LO for heating. I wound up installing the non-exact motor yesterday using the HI and LO connections and had a pleasant cool night of sleep.
And yes, I replaced the cap.
fitter30
Peace Valley,mo
There isn't much difference between a 3&4 speed motor. Have a 10 + year system and use a pleated filter? AC Coil still dirty and blower wheel.
mm08822
Would have been a good time to check furnace heat exchange fins for debris buildup too, while the blower housing was out.
D
dwasifar
AC coil is about 8 years old. I blew off the squirrel cage with compressed air before reinstalling.
Yes, it would have, darn it.
