AC wiring question
johno
Southern Ont.
I'm installing a used Mini Split , ductless,AC unit in garage.
I know what the electrical demands are, ie amperage ,wire size, breakers etc.
What I don't know is
Does the wire go to the outside unit, and then run back to the inside unit, or are they two separate circuits, or something else I haven't thought of?
Thanks
PoorOwner
CA
the main power just connect to the outside unit then there is a usually separate 4 wire cable that runs from the inside unit to outside unit (known as "communication cable" or "interconnect cable" ).
You don't need to be concerned what circuit or voltages for that 4 wire cable as long as you don't mix up the terminals. (they are assumed to be protected by the outdoor unit circuitry) But some jurisdiction will want you to put in a disconnect to cut off this communication cable because in all cases they carry some sort of voltage and they want to be sure the indoor unit can be shut off separately for servicing. In practice I don't think most people add that disconnect between the inside and outside unit.
J
johno
Southern Ont.
Thanks for the reply.
Is this interconnect cable carrying line voltage?
By which I mean 120V?
brewchief
Yes line voltage to run the indoor fan, probably 240v.
Every mini I have installed has called for a stranded wire instead of solid for the interconnect wire, it is very hard to find except from the companys that sell mini splits. Many wires that seem suitable are considered cord and can't be run through walls.
Trey T
Houston, TX
They're the same circuit. The wall unit or ceiling cassette will require power and control wires to be fed from the condenser outside.
Mini-split wiring is pretty dummy-proof and well designed system.
