Acceptable quality snap ring pliers
BajaBound
Nor Cal
I am also looking at the sunnex set there is also set from knipex. Sunnex is gonna start getting more of my money.
chad99
Main thing is that they are reversible...as the sunex are.Removing a snap ring really isn't a high stress scenario.As long as the tips fit in the holes,you are prob good to go.And it looks like the sunex set might be able to handle a.wider variety of clips.I imagine the sunex would be fine.
MattPersman
Indiana
one thing i have run into with the knipex (I have them) is the tips are a little big for much of the smaller snap rings I have come across in the past 2-3 years. do not know if it is coincidence or holes have gotten smaller on newer stuff. but the sunex set has smaller tips .038" instead of .049". just something else to consider depending what you are using them for.
D
Daniel831
Thanks for the feedback, I'll follow up with a review when I do make my decision
cbracer
Costa Mesa, CA
Craftsman and many other brands simply rebadge similar pliers. I've been debating on the following two designs but don't know which one is better. Anyone have some good feedback about these?
Seanbev24
Lynnwood, Wa
Snap ring pliers are right near the top of my list of tools that need to be top quality. I got by with cheap ones for years, bending/breaking tips and digging the partially removed snap ring out with a pick.
I have the Craftsman pro convertible pliers and hate them. It's a waste of time changing tips and they're **** for larger snap rings. Since they do work well for small ones, I leave the small tips on them and bought this set for everything else...
http://buy1.snapon.com/catalog/item...roup_ID=675128&store=snapon-store&dir=catalog
At first glance they look like everyone else's pliers, but they're much more solid and better built. The Knipex pliers look great, but the Snap-ons are easier for me to warranty if I ever have an issue.
OP, I don't have specific experience with the Sunex set, but I've just had horrible luck with "acceptable quality" snap ring pliers. If these are gonna be for pro use, it really is worth spending some more money. The Sunex set will probably work, and is probably a good choice for weekend use, but it's not going to fix your hatred of snap rings.
yogitech
Orlando, FL
Ive been using the above mentioned Sunex set on a pro level for the past six years. There just now starting to wear out the tips. I did have one of the 90* ones that I warrantied out due to cracking at the bend. I believe it may have been a deffect, the replacements are doing great.
Over the last year I did buy some Snap On in certain sizes due to a "tighter" fit in the openings. Those are really nice too:thumbup: But, I would deffinetely purchase the Sunex set again if it were'nt covered under warranty.
Steve_P
I have two knipex pliers with .035 tips, so you need to spend more $$ and get these :lol_hitti.
gsmornot
Inside your screen
I have the set on the right and have used them for years with no issues. The tips are replaceable if you break them but I never have.
chappys4life
I have the set on the right and I hate them! Changing the tips are a pain to. On first tip change the included wrench stripped. I am watching this thread trying to find a replacement for them.
eBell
Mmmmm, snap ring pliers. For me they're not needed often but when I do I REALLY do.
Gave in and finally bought a nice S&K set this past winter. Made in the U.S.A.
I've used them about 5 times so far and unlike other versions I've owned these didn't
have me digging through my mind for the appropriate swear word.
Got them on Amazon. You may be able to find them cheaper somewhere else but I was already there buying other items.
http://www.amazon.com/dp/B0009WRL3I/?tag=atomicindus08-20
Let's see if I can get away with a link to Amazons picture of them:
franzdom
NC
I take it by 'acceptable' this is not what you were looking for:
gsmornot
Inside your screen
Wow. Maybe I'm missing out and just don't know it. Such a strong feeling for something that has for me worked well. I guess part of it may be that before these I just used two screwdrivers and pried the rings out. I get better as I go but maybe I'm still not there yet.
XaqNautilus
Alberta
I've been eying the ChannelLock circlip pliers for a while now. Only brand I've seen in person besides some uber cheap ones at Princess Auto for $5 but I'd never buy those.
frankush
IL
I have the SK set as well. I got tired of the replaceable tip versions. Works great for me.
NC-Fordguy
This thread is just on time
I have a crafty set and it has served well--just hate changing the tips during projects.
Is the S&k set reversable or are they specific to internal or external rings?
eBell
They're reversable. That knob in the center is the cam-lock bit for the change from external to internal. Just twist and you're heading the other way.
I'll admit I tried out smarting the tool the first time and thinking I'd bound one up. Guess I couldn't accept it would be that simple.
Mike007
Ive got a question for anyone who has used this SK set. Does the knob ever get in the way on the cam lock if you are trying to remove a snap ring in a tight space? I'm trying to decide between cam lock and the standard type. :headscrat
