Accu-Gage H100X $13.25
moonley
Accu-Gage H100X Professional Tire Pressure Gauge with Protective Rubber Guard (100 PSI). Free prime shipping. Lowest price per CCC; I bought it at $14.75 this morning but it has dropped even more since then, usually goes for almost $20.
http://amzn.com/B00HESFIJ4
moonley
Well, it showed up today, but was missing the "protective rubber boot" that it is supposed to have. Packaging even stated it was supposed to have "protective rubber boot" and appeared to be unopened.
Processing a return with Amazon, this one was sold by Etailz and fulfilled by Amazon, so at least the return was easy.
Actually works out because I paid $14.57 and now I'm purchasing another at the cheaper price. This one is sold by Jazebra and fulfilled by Amazon so I'm hopeful for getting the right one.
BikerDad
Utah
Unless inflating truck tires, wouldn't the 60psi one be easier to read?
Good price on the 100psi model. :)
Trucks. And bicycles. Actually, 100psi is on the low end for quality road bikes. They tend to run 115-125psi.
CNGsaves
KS and OK
These work for both schrader and presta valve stems ??
Or is there adapter of some sort for smaller presta valve stems (ie high pressure) on bicycle tires ??
t1r2u3s4t
I have the 60psi right angle one for car and motorcycle. these are great and cheap, get the boot
ratchetcat
Thanks for the heads up on this deal. I needed a good pressure gauge. Mine just arrived. Seem to be robustly built and easy to read. I *really* like the retained reading / hold valve feature on these, too.
mrborohachi
Berdoo Route 66
I'm in for a #H60x (60psi max gauge) only: Order total: $18.95
I'm not filling road bike tires hahaha
http://www.amazon.com/dp/B001AT0YU6/?tag=atomicindus08-20
After you check the tire pressure remember to take the adapter off and tighten the presta valve stopper. My father was always complaining about his tires on his 29er MTB going flat. He had two adapters on at all times. He'd fill the tires and never tighten the stopper
mrborohachi
Berdoo Route 66
Can anyone that bought this guage please unscrew the hose off the air bleeder section and see what the orientation of the Spring, black rubber washer and white plastic washer is. My father was using my guage and somehow unscrewed the hose off the guage and I don't know how it's suppose to go back together.
Thanks
Chev89
I've see Digital ones with cheaper price/ Why is this recommended? Just curious
moonley
Oh yeah, I got the second one I ordered the other day and it was the correct one with the rubber guard. Not that it matters, deal appears to be dead.
