Acetylene opening/closing tool?
drummerdimitri
Beirut, Lebanon
I received my Acetylene tank today and was surprised to see that it does not come installed with a valve on top like the ones you see on the oxygen and propane tanks to open and close the tank's outlet.
Asked the seller how to open and he said that the tool was supposed to come with my regulator but that wasn't the case and he doesn't have the tool to sell me so pretty much useless if you ask me.
From the looks of it it seems like a square drive but I'm not sure what size fits it as it seems to be conical.
Is type of control mechanism usually found on such tanks or is it not common where you guys are from.
Can anyone identify what kind of connector this is and what tool is needed to open it?
rlitman
Long Island
In the US, there are four types of acetylene valve stems. Two use the same small square key, one uses a larger square wrench, and one has a hand knob. None have a yoke like that. We reserves yokes for breathable oxygen.
shopping
shopping
Does that whole upper knob assembly turn? Could you put big adjustable across the flats? Otherwise, if only the square turns, you can use a 12 point socket of appropriate size.
That sure looks like a packing nut to me. I would not risk turning the outside flats. As with any flammable gas valve that uses a key or wrench, the wrench should be left ON the valve while in use, so it can be quickly turned off. That is why we do not use open wrenches on welding gas valves (they would fall off).
GeoBruin
shopping
shopping
Good call. I modified my post to remove the bad (dangerous) suggestion. I didn't even consider why I hadn't seen a bottle like the OP's until you mentioned regional differences and then I noticed OP is in Lebanon.
