haugy
I've searched this all over. But figured I'd ask a comparison question.
I'm looking at a PolyUrea coating for my new 2,000 sq/ft floor. The concrete is 4 months old, and has been protected with 15mil plastic from anything that had to be parked inside during that time. The concrete has a smooth finish, but not polished.
So my questions are around the prep. The concrete is clean, no powder on it, it was a great pour. And the supplier I'm going with recommends an Etch as long as the concrete isn't powdered with excess creamy layer and stuff on top (which it isn't).
My rub is, I've never done etch. I've done grind before, and while that ***** in comparison on a 2,000 sq/ft, at least I have an idea what I'm doing.
I've read the processes on etching a ton, and I'm just nervous I guess. I've also read on Allgaragefloors that any good coater will grind before, but that many are starting to switch to etch.
Seems easy enough, mix solution, spray solution, keep wet. Then neutralize after the time with baking soda/water or ammonia/water mix. Then rinse clean really, really well. Wait a long time for the shop to dry out. And go.
Those who have done etch, any tips, any thoughts? Would you etch again?
