+1You put a light broom finish on the concrete, then you turn around and grind it off before you acid etch??? Or am I confused? Thannks.
The profiling can be done with acids or by grinding or shot blasting.
Take a look at this blog article. Acid etching is not a great way to go about it. You are far better off mechanically grinding.
Acid Etching Concrete Pre-Epoxy - Why It's a Bad Idea
I tried to get all the information I could on etching and found most of it confusing and much of it conflicting to each other. Some advocated a special type of neutralizer, some not, but I never had an adhesion problem although I always water blasted the surface thoroughly and I never neutralised.
Concrete is alkyline (base) and acid...is an acid. What do you get when you mix a base with an acid? Answer: A salt and salt is corrosive. You should neutralize the acid somehow, you can use sodium bicarbonate (baking soda). At the very LEAST, wash the concrete thoroughly.
Muriatic acid reacts with the calcium in the concrete, that reaction does neutralize the acid, but there's no guarantee that there's enough calcium to fully neutralizer all the acid. Likewise exposure to air also neutralizes the acid, as does the water used to dilute the acid, but even then the acid may still be a bit "hot". That's why you should use baking soda in addition to flooding the floor a couple of times.
Pretty much all the pro contractors will grind or shotblast to prep, but even they will use acid on occasion, like in a situation where it's critical that no dust be generated, like a micro-chip facility.
I'd say that probably 80% of our DIY jobs acid etch, and we haven't had any problems with our BondTite primer lifting from the concrete yet.
I just did acid etching last weekend on my driveway curbing, the firts thing in the instructions stated no not acid etch , it will effect the lime in the concrete and you wont get the full effect of the acid stain, my concrete was 30 days old and stained corectly. i`m no expert but it worked.
