Diy'er first time garage floor. Going to be using rust bullet duragrade coating on this floor. 2x. Flakes, clear coat with anti slip added.
Here are some after pictures of the prep and close ups of the really etched areas and some that I think might not be? I'm worried I didn't do enough etching and cleaning.
Process was as follows
This is model home concrete 1+ years old. No stains, cracks etc. I washed and scrubbed concrete. Then did 3 10x10 squares with a 3:1 water to muratic mix with what I thought was terrible results. Even though I'm not entirely sure what I'm looking for as a result. Some of the thicker areas I sprayed, you could really see the difference. So I figure that's what texture I should aim for? Can see in the attached pictures.
Following day I did a 50:50 mix. That seemed to work way better, I got yellowish foam and steam coming off the concrete. And these results seem much more favorable for getting a grittier surface. I heard to NOT let it dry, I had issues with this both days, had to go back and recoat areas so this wouldn't happen, and I prewet each 10x10 area. In a few videos I've seen, the guy coats the whole garage in acid and then washes it out. I have to assume he is letting it dry since these garages are larger than mine?
Anyway, after that last etch, I thought 75% of the floor seemed to be etched enough so I cleaned and power washed the garage twice. I'm now on day 3 of waiting for the slab to dry. Attached are pics. You can see where the power washer left marks, does that mean it's not clean enough for rust bullet? Should I power wash even more? Do I need to etch the floor more? Or will this be good for rust bullet?
