Acid Etching Walls
SH_82
Midwest
Have a home built in 1960 and I'm renovating the garage. I have bare concrete on the walls that I plan to use Loxon Primer/Sealer prior to painting with an exterior latex paint.
Would it be overkill to acid etch these walls or will the Loxon probably adhere well enough with 2 coats?
PCustoms
VT
That does not look like 1960 concrete.
Either way I'd paint directly on it.
Toolfool
Columbus, Ohio
What about acid staining. I've done a bunch of floors using a waterborne acid stain ( Kemico) that turn out really well. Recently stained the slabs I poured for a 500gal propane tank and a stand-by generator with stain I had left from a job a few years ago. Other pic was the part of my old garage I turned into an exercise room.
S
SH_82
Midwest
Are the concrete walls retaining walls?
Not sure what you'd classify them as but basically on 2 of the 3 non-garage door walls there is this concrete about 3 feet high and then sheet rock the rest of the way up. The odd man out wall just has plywood
Stuart in MN
Minneapolis
I think what he's asking is if there's earth against the outside of the concrete or if they are above grade. If there is dirt on the other side you should probably make sure the walls stay bone dry, or paint will have a hard time sticking.
Personally, I'd be reluctant to paint concrete...once it's painted, you're doomed to having to repaint it every so often for the rest of time.
S
SH_82
Midwest
Ahh thanks for clarifying. That does make sense. Yep, one wall is above grade and the other has dirt up against it with a raised flower bed.
Will Loxon XP primer help block out that moisture? Are there any other sealants that may help in this situation?
