Acid Stain Manufacturers Question
av1
I just finished putting down some Quikcrete acid stain in my basement garage. Waiting on an order of clear polyaspartic from Legacy to use as a top coat.
av1
Where did you get the quickcrete? How much was it?
Do any of the big box stores carry Acid Stain?
Picked it up at Lowes.....$72/gal. Coverage is 300-400 sqft/gal depending on how porous the concrete is. My floor is 15 yrs old,700 sqft, previously painted & prepared with a diamond grinder. I used about 1.5 gallons.
Quikcrete acid etching stain comes in 3 flavors....tan, coffee & cayenne red. I used the coffee. According to Scott at Legacy his polyaspartic will go over any manufacturer's acid etch. I believe Legacy also sells it's own acid etch as well.
L
les_garten
PSL, FL Next door to Megan FOX, and down the stre
Thanx!
LegacyIndustrial
deerfield, IL
Scott is correct. We can top any acid stain, although we are partial to our own. Les be sure to neutralize and double rinse or you will have issues with topcoat.:thumbup:
L
les_garten
rbmedic75
for my application the topcoat wont work. I do a lot of welding, grinding, plasma work and any topcoat is going to burn off. Which is why I have been looking to a product like a densifier or possibly the radonseal stuff that penetrates into the concrete and leaves nothing to peel, burn or flake off
LegacyIndustrial
deerfield, IL
I would love to know more too!
We don't analyze our competitor's products. This would be anti-productive.
All I know is that a sealer will not eliminate radon. I can say this from talking to experts in relationship to my own radon issues.
If you want high quality flooring products with as much help as I can supply then call us.
L
les_garten
Ahh Come on...
You must have an opinion on competing products and technologies, to say differently is ddisingenuous.
I will say, that I called these guys today. The call immediately went to Voicemail, and they never responded to the voicemail I left. Basically, third rate BS here.
rbmedic75
not looking for it to seal radon. they have a different material for that i think. looking for a color and sealer that is oil/fluid/burn proof. I have seen many opinions on other products here?? if we cant get a hold of them thats a different story and a dead duck
L
les_garten
Triple Hurricane warning Flag if they don't answer pre-sales calls...
LegacyIndustrial
deerfield, IL
Les:
The gods have answered your prayers. We are releasing a new NON-ACID stain that is designed to be used with indoor or outdoor concrete. It gives far more coverage per gallon, has excellent UV stability and is priced right. Not only will it stain concrete but it contains densifier. Therefore it strengthens as it stains.
In addition to this stain we will be launching a companion sealer that is designed specifically to work with this stain.
All these products are GREEN and will compliment your property making it look like you hired a PRO. Look for more information on our web-site by end of this week.:beer:
L
les_garten
Les:
The gods have answered your prayers. We are releasing a new NON-ACID stain that is specifically designed to be used with outdoor concrete. It gives far more coverage per gallon, has excellent UV stability and is priced right. Not only will it stain concrete but it contains densifier. Therefore it strengthens as it stains.
In addition to this stain we will be launching a companion sealer that is designed specifically for outdoor use.
That sounds interesting. I'm finishing movig this week. The weather got so hot so early this year, I figured I may have to wait till the fall.
LegacyIndustrial
deerfield, IL
L
les_garten
Les:
I am not sure how many square feet you have but if you added bodies and did this in the evening, you would be good. Here are the links for the stain and sealer.
STAIN:
http://legacyindustrial.net/cart/concrete-stain-and-densifier-800-sq-ft-p-242.html
SEALER:
http://legacyindustrial.net/cart/hd415-concrete-sealer-600-sq-ft-p-243.html
We will have sample kits available in a few weeks.
Thanks and good luck.
Hey!
That's interesting news!
I have about 1600 sq' if i remember correctly.
