Acid stained floors
juddspaintballs
Hedgesville, WV
We are building a house on a slab. The concrete is about a month old at this point. We're maybe a month away from drywall. The wife and I decided we want to do acid stained floors in some sort of grey or slightly darker (not black) color, but a little more exciting than just sealed concrete. Anyone have brand suggestions?
Shea
California
That stain doesn't seem to have a color like I'm looking for and my wife definitely doesn't want glossy finish.
Acid stains consist of earth tones. You may want to look at water-based stains/dyes instead. We just posted an article about a couple that did their basement with water-based stains and a matte sealer.
J
juddspaintballs
Hedgesville, WV
I just read your articles yesterday.
How does this sound (after educating myself a little better)?
Delta Dye and TS210 matte sealer.
Should I need to acid etch my floors? They were power troweled and water doesn't readily soak into the floors from what I can tell. I have a concrete polishing machine I could put sanding discs on...
Shea
California
Yes, the surface should be lightly etched or sanded if water sits on the surface. Just know that etching can't be controlled. Color tones can get splotchy and areas become more porous than others due to the varying density at the surface. This is fine if you want a floor with a lot of character when you apply the stain. Sanding the surface would be better if you want something more subdued. Don't go too crazy on the grit though or you will have swirl marks. If you sand, make sure to do some water drop tests to verify that it's effective.
