hmmmmm... i didn't think of that. i didn't know RV's come in 220 volt configuration
That is my point, they usually don't.
However, a 50 amp socket in a garage is almost always 220.
My neighbor a few years ago plugged his 50 amp pusher into an adaptor he made himself and plugged it into the '50 amp' socket in his garage, that the previous owner had put in for his welder.
Fireworks happened.
Guys who don’t have RV’s will often tell you that ’50 amp is 50 amp’ forgetting or not understanding that the 50 amp in a house or garage is 220, not 110.
On my Class A I never use the roof a/c in my yard so I just use a 30 amp to 20 amp adaptor and run it on a regular outdoor wall plug.
If I wanted to use the roof a/c while it is docked at home I would have to put in a 30 amp. The rest of the rig uses less than ten amps at full usage, the A/C draws about 15 amps, so as long as I don't turn on the A/C I don't need the 30.
If you have two roof A/C then you usually have a 50 amp 110 plug.
