Add future water to detached garage?
aggie113
San Antonio, TX
Of course end plans would include connecting to house septic, but... for now I may have a chance to nearly add water my detached garage. The house and garage are about 70ft from well pump/pressure tank. In a few weeks/month I will be getting solar installed and part of this will be running new trenched conduit from the meter poll (10 feet from the well) to the garage. I figure why not take the opportunity to shove some pex line in the same hole they trench for the power conduit? Thought I would see if I'm mad or crazy here before bringing it up with the installer. Everything electrical will need to be up to code, fyi. So can I save some $$ on future trenching work?
dcg9381
Austin, TX
Here you can run water in the same trench as electrical, but there may be code requirements on separation.
You could simply add an empty conduit, say 1-1/2 with sweeps. Basically a "sleeve" for future PEX water line. Might keep you out of trouble with inspection. The purpose of PEX is obvious. The purpose of empty electrical conduit, not so much.
tarmy
Nor Cal
Run a couple extra 1” conduit, water, and run a sani line for slop sink and toilet too. Putting all that in the trench is a few hundred bucks at the most…keeps all your options open.
OccupantRJ
Eastern North Carolina
Check the fall on the future desired sewer line. I ended up using a sewer grinder pump with a 2” pvc line to my septic tank along with water line and conduit for network in the same trench
A
aggie113
San Antonio, TX
Septic line is not going the same direction as the well :)
That would be back towards the house which is down-slope a good amount and only 40ft away. Thankfully pier and beam setup and the original (not used) septic hookup is on the side of the house facing the garage so shouldn't have any issues putting it in, other than you know, putting it in.
njk4o5
Boston, MA
i just did this for mine, i tossed a 3/4 pex CW line in the power/internet conduit trench. About 75' from my house maybe 8' gain in elevation and it works fine.
joe_padavano
Northern VA
Why are people wanting to use PEX for this? Get direct burial plastic well pipe and don't look back, I've run water to several barns and garages on my farm with this. Some of it has been in the ground for 25 years with zero issues. The longest is over 500 ft and one even went under a stream. Yes, I put it in the same trench as the electric (they run right next to each other in the walls of your house). I also bedded wires and pipes in stone dust prior to backfilling.
Oh, I forgot, this is GJ, where overthinking is mandatory.
A
aggie113
San Antonio, TX
I'm wanting to use pex for this because it's not going to be finished. So I'll have several feet curled up at each end for when I do finally run water to the garage. I don't plan to need more than a sink and a toilet (eventually) that it'll feed.
dcg9381
Austin, TX
I used PVC (2") for the water line due to calculations on length and rise. With 2" basically the pipe had very little impact on water pressure.
I'd have used PEX - it's tougher than sch 40 PVC, more flexible... The only struggle is getting it to be straight. But once you get to sizes of 1" and above, it gets expensive.
dave*99
Coastal NJ
1" PEX is about twice the price of the black poly pipe. All the water services and sprinkler systems by me are poly.
Terminate it with a hose barb and ball valve and connect whatever you want in the building from that point on.
