Just purchased a house and am trying to plan getting more power to the garage because of course that is the most important thing to worry about when first moving into a house....right? Anyway, all comments will be appreciated.
-House is 2 stories built on a slab with attached 21x20 garage (living space above garage). Service panel is 200A with 6 open spots. Panel is on ground floor, 25 ft from garage. Garage and first floor are both finished.
- Would like to add 3 20A circuits (1 for lighting, 2 for outlets).
Finally, for the questions. Do I want to run 3 separate circuits from panel to the garage or run a sub panel? And either way I go, is removing the baseboard and cutting a few inches of drywall near the floor generally the easiest way to run cable through a finished ground floor with living space above? Thanks in advance.
