bad_idea
I am in process of building out the mechanical room in my home. I absorbed a chunk of the master closet into the mechanical room to add space for a server rack (geeking out with the home network / automation stuff). The room is now 6'x7' and houses the air handler, water heater, water softener, main power panel and the server rack.
My house was built in 2005 and has hardwired smoke detectors in each bedroom, the main hall, and the living room. I am thinking it would be a good idea to add a smoke detector into the mechanical room - my thought is the equipment in the room is a likely source of a fire. Would I be adding a source for nuisance trips of the alarms? The nearest detector is the one in the living room which is in the middle of the run. Do the alarms need to be in series, or can I tap into a sensor in the middle of the run?
